using a wide composition
basvcds
Post by basvcds »
Hi Guys
For my next gig i would like to use an ultrawide composition, using one beamer. Ik have a comp running 1024x320. When i enter fullscreenmode, the image scales up to 1024x768, or whatever native res i run it in. I then tried using switchresX to make a costum resolution but this also just scales up the image. Then i tried windowed mode, but then i would have the title bar showing, i could position the window in the top part of the screen but for that i would have to adjust the beamer wich i rather wouldnt do.
Does anyone have any tips for getting this to work? many thx in advance!
HerrNieDa
Re: using a wide composition
Post by HerrNieDa »
in this case you shoult use 1024x768 as composition resolition and scale/position it in the composition properties!
if u use composition effects you should also use a mask maybe!
