Hello,
I just switched from one MacBook Pro to another.
As my paths/directory/username is now different than my old laptop, it seems Resolume can't find the films when i open my old compositions.
Anyone know what the problem is ?
Or how i can input the right directory folder for Resolume to recognize where my films are ?
thanks,
Stephanie
						Directory problem Res3 on Macbook Pro
Re: Directory problem Res3 on Macbook Pro
the composition files are saved in xml format
so you can edit those in a text editor...
just replace the old directory-entries with the new directory and it should work again.
maybe another possibility is to set hard-links instead of copying the clips in the old directory, but i've just done this on windows, don't know how or if it works on osx
