I`ve a question about using two different software during a live gig.
I want to combine resolume with robotfunk flowmotion_ switching these programms with a video mixer.
Is the use of two different programms possible, or can this cause problems?
please feedback
vjing with two different programms
combining the outputs is not possible!!
if u are using output via second screen, do not use dvd max or theater-mode, you can use two programs, and if switching the output will change, i used this once with winamp and resolume and also had a power dvd running worked fine, this weekend i tried to run again but if u are using theater mode it wont work
under normal circumstances, i strongly suggest that allways using 2 different video signals from 2 different hardware.
at the moment we are using 2 arkaos with live feed + 1 dvd signal for emergencies. all mixed up in a video mixer. we are also using an external camera.
in long term we are planning to use 1 arkaos 1 resolume. both software looks similiar but they have some differences + advantages and disadvantages to each other.
