hi running resolume 313 on mac os x snow leopard and sometimes, when ive made a jpg (in PShop3) itll appear in the files window and i can drag it over to the clip column, but the clip slot wont highlight yellow and the slot wont accept the file...??
any ideas?" anyone got the same problem.
restarting resolume seems to help but thats really not a solution
thakns
harky
						Cant drag in JPEG sometimes
Re: Cant drag in JPEG sometimes
Hey Harky
Try dragging them from Finder. If it works that way, you've stumbled across a bug that will be fixed in the next update. If not, please send us one of the offending .jpgs, and we'll have a look.
We had some issues with Drag & Drop operations, these are resolved for the next release.
Had this problem
Be shure to save jpg in RGB color space
