why should I choose resolume?
Kurt_
Post by Kurt_ »
Hello!
I'm very new to all of this - stumbled upon this application through the vjcentral site (which I also only stumbled upon a few days ago). Anyway, I downloaded the trial version and have been playing around with it - I really like what I see, but I can't help having the feeling that the other applications out there can do more. So why should I stick with this program? Again, I had it up and running within a few minutes and I like the feeling of it but how does it compare to Flowmaster for example. Please convice me to stick with this program.
Thanks.
Kurt
edwin
Post by edwin »
I think you mean flowmotion,
well i have to say that you've have to decide for yourself what feels better, each piece of software has it advantages, we like to think that our software is easy to use and user friendly. So in the end you should choose what feels best, but hey resolume is the best there is ;-)
cheers
edwin
[Modified by the moderator on: 2004-02-08 11:47:56]
[Reason: ]
whiterabbit_
Post by whiterabbit_ »
STICK WITH RESLOUM BECAUSE IT IS VERY ACCESIBLE AND VERSATILE, WITH THE RIGHT COMPUTER AND A BIG ENUFF HD YOU CAN ACTUALLY PLAY FULL AVIS AND ADD EFFECTS TO THEM RECORD LIFE AND WITH THAT MAKE EVERY SHOW UNIQUE AND IT IS EVEOLVING FAST .....IF SOON IT WILL INCLUDE IMAGE TO SOUND ANALYSIS AND INCLUDE A CUSTOMISE HARDWARE ..I'D RATE IT THE BEST WARE AVAILABLE BUT THEN THAT IS MY OPINION......GOOD LUCK....THE RABBIT
Kurt_
Post by Kurt_ »
Thank you. That's exactly what I wanted to hear. I liked it right away because it seemed very easy for me to get started compared to other programs I'm testing. By watching this discussion forum I'm also now conviced that this program has a strong following and thus a bright future. I'll be purchasing soon and look forward to using it.
Kurt
