i have an event where i will need a few live feeds. am i right thinking that i need to use different cams instead of several of the same to avoid problems?
when you say cams i suppose you mean webcams, and yes, if you need several webcams then you need to have different models, if you have the same model then you will only see one webcam in your list.
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000 )
