hello, i learn resolume, trying to put some text from flash into resolume, however if i follow manual i cannot get it,
i have version 3.0 and a flash is version 9 CS3, i use action sript2, i format text as dynamic but i don't have window variable(to put rtext inside), maybe this is a problem,
actually i published a swf file on desktotp but i cannot access it via resolume file browser at all, not even after refresh browser,
need a tip, cheers!
flash text in resolume
Re: flash text in resolume
flash is supported from Version 3.1!
hi to all...
I'm having the problem... where can I find a tutorial that explains how to load flash into resolume....
thanks in advance
thanks in advance
VibemasterBert
you can load your swf-files like any other video-file into your composition.
for more infos about using flash in resolume read the manual:
http://resolume.com/avenue/manual/
