vision switching of dual DV inputs
Matthew Rendell_
Post by Matthew Rendell_ »
Hiya evry1...
does anyone know if this (or any other software) allows vision switching of dual DV inputs??
I work at a university, and we are looking to stream our lectures (not EXACTLY WHAT THIS SOFTWARE IS FOR I KNOW!!) and we need to digitise 2 DV inputs, and then vision switch between them, then DV out to a DVCAM recorder..
Any help would be fantastic..
Matt R
Flinders Uni of South Australia
evomedia_
Post by evomedia_ »
there are 2 separate issues here, you can easily mix 2 dv signals with a vision mixer that take dv inputs.
Something like the videonics mxprodv
http://www.focusinfo.com/products/MXProDV/mxprodv.htm
That way you have 2 dv inputs as well as 1 digital output for your dvcam recorder, now you can either use the dvcam as a thru, and send the signal from the dvcam recorder to a steaming server, for network broadcast, or use another of the analogue outputs as the source for the streaming.
If you still dont have a idea how to broadcast over a network then you'll have to decide on a budget, as you can have from basic solutions up to tv quality solutions such as viewpoint vbx:
http://www.viewcast.com/products/vbx/vc ... erview.htm
evomedia_
Post by evomedia_ »
or just the streaming device, this actually has the option of a mxprodv as part of the package:
http://www.viewcast.com/products/Niagar ... erview.htm
evomedia_
Post by evomedia_ »
this model is fairly basic but has dv input for streaming
http://www.viewcast.com/products/Niagar ... 115rw.html
