crash when removing effects
macrosoft
Post by macrosoft »
Hi
Avenue works fine, except when i want to remove some effects, such Pink, BrightLines among others.
Avenue CRASHES .
Does it happen to anyone?!
any suggestions
Thx !!!
Version: Avenue 3.1.3 (i had the same problem with version 3.0)
Files encoded: DVX - some of them with audio included
Laptop HP: dv7-2070ef
Vista sp1 (32bits)
IntelCore2 Quad@2.00GHz
Ram:4G
ATI Radeon HD 4650
Re: crash when removing effects
Hey Macrosoft.
Thanks for the crash report. Could you send an email to support[at]resolume[dot]com, with the logfile that Avenue creates on your computer (C:/Documents and Settings/[username]/Application Data/Resolume/Resolume Avenue 3 log.txt)?
Hopefully that will show us what is going wrong!
