i own a notebook with a GeForce 105M onboard.
Its supposed to be better tha GeForce Fx5200, but Resolume 3 says that the card isnt supported...
http://www.notebookcheck.net/NVIDIA-GeF ... 790.0.html
I try with nvidia latest drivers, and omega drivers...
But still cant start resolume 3 avenue...
Why??
Thanks.
						GeForce 105m - Compatible?
Re: GeForce 105m - Compatible?
Hey Kurk
From what I read on the Notebookcheck page, this is one of those NVIDIA cards that thinks it's smart and decides on its own whether it should use dedicated memory (good) or shared memory (bad). When running in shared memory mode, Resolume doesn't want to play with it.
Notebookcheck also mentions something about being able to set this manually, so maybe you could look into that? As spec wise it does look like a decent card.
Hope that helps.
Hope that helps.
good point, Thanks...
i was using windows 7, and doesnt work even with latest drivers... so i do a complete reinstall with xp and latest drivers from nvidia, and finally resolume start with 105m...
Regards, K.
Regards, K.
