my composition suddenly creates a crash when opening in Resolume. I rebuild it from a older version and the problem returns. The composition initially works correct but when I close and re-open it it crashes.  All software is up-to-date. Here are my logfiles:
$357
$358
$366
$211
$382
$196
$256
$324
$257
$396
$201
$193
$165
$321
$326
$400
$322
$315
$319
$141: 120
GL_APPLE_aux_depth_stencil
GL_APPLE_client_storage
GL_APPLE_element_array
GL_APPLE_fence
GL_APPLE_float_pixels
GL_APPLE_flush_buffer_range
GL_APPLE_flush_render
GL_APPLE_object_purgeable
GL_APPLE_packed_pixels
GL_APPLE_pixel_buffer
GL_APPLE_rgb_422
GL_APPLE_specular_vector
GL_APPLE_texture_range
GL_APPLE_transform_hint
GL_APPLE_vertex_array_object
GL_APPLE_vertex_array_range
GL_APPLE_vertex_program_evaluators
GL_APPLE_ycbcr_422
GL_ARB_color_buffer_float
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_object
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_shader_objects
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shadow
GL_ARB_texture_border_clamp
GL_ARB_texture_compression
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_non_power_of_two
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_transpose_matrix
GL_ARB_vertex_blend
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_window_pos
GL_ATI_separate_stencil
GL_ATI_texture_env_combine3
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_EXT_depth_bounds_test
GL_EXT_draw_buffers2
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture_array
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_s3tc
GL_EXT_texture_env_add
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_rectangle
GL_EXT_texture_shared_exponent
GL_EXT_texture_sRGB
GL_EXT_transform_feedback
GL_EXT_vertex_array_bgra
GL_IBM_rasterpos_clip
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_depth_clamp
GL_NV_fog_distance
GL_NV_fragment_program2
GL_NV_fragment_program_option
GL_NV_light_max_exponent
GL_NV_multisample_filter_hint
GL_NV_point_sprite
GL_NV_texgen_reflection
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
$192
v1.1 (100 % - 7/7)
v1.2 (100 % - 8/8)
v1.3 (100 % - 9/9)
v1.4 (100 % - 15/15)
v1.5 (100 % - 3/3)
v2.0 (100 % - 10/10)
v2.1 (100 % - 3/3)
v3.0 (91 % - 21/23)
v3.1 (12 % - 1/8)
v3.2 (33 % - 3/9)
v3.3 (0 % - 0/9)
v4.0 (0 % - 0/13)
$390
$391
$116
$114
$118
$120
$122
$128
$123
$125
$129
$132
$140
$386
$388
$310:
$384$384$384$385$385$385$385$385
Process:         Avenue [389]
Path:            /Applications/Resolume Avenue 3.1.3/Avenue.app/Contents/MacOS/Avenue
Identifier:      com.resolume.avenue
Version:         3.1.3 (3.1.3)
Code Type:       X86 (Native)
Parent Process:  launchd [86]
Date/Time:       2010-04-11 15:18:57.060 +0200
OS Version:      Mac OS X 10.6.3 (10D573)
Report Version:  6
Interval Since Last Report:          3447 sec
Crashes Since Last Report:           11
Per-App Interval Since Last Report:  1310 sec
Per-App Crashes Since Last Report:   11
Anonymous UUID:                      514E6DED-DE03-4017-A00E-FB867E12C599
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000023e6e000
Crashed Thread:  13
Thread 0:  Dispatch queue: com.apple.main-thread
0   com.resolume.avenue           	0x002269c4 0x1000 + 2251204
1   com.resolume.avenue           	0x0022af7e 0x1000 + 2269054
2   com.resolume.avenue           	0x0022b970 0x1000 + 2271600
3   com.resolume.avenue           	0x00211909 0x1000 + 2165001
4   com.resolume.avenue           	0x002119a3 0x1000 + 2165155
5   com.resolume.avenue           	0x001848d1 0x1000 + 1587409
6   com.resolume.avenue           	0x0018491f 0x1000 + 1587487
7   com.resolume.avenue           	0x001849f3 0x1000 + 1587699
8   com.resolume.avenue           	0x0016496c 0x1000 + 1456492
9   com.resolume.avenue           	0x000f8436 0x1000 + 1012790
10  com.resolume.avenue           	0x000b191a 0x1000 + 723226
11  com.resolume.avenue           	0x000b08e6 0x1000 + 719078
12  com.resolume.avenue           	0x0005b4b2 0x1000 + 369842
13  com.resolume.avenue           	0x0003b113 0x1000 + 237843
14  com.resolume.avenue           	0x0003b8de 0x1000 + 239838
15  com.resolume.avenue           	0x00158cc3 0x1000 + 1408195
16  com.resolume.avenue           	0x002a2098 0x1000 + 2756760
17  com.resolume.avenue           	0x0029aa5e 0x1000 + 2726494
18  com.apple.Foundation          	0x978d3eac __NSThreadPerformPerform + 705
19  com.apple.CoreFoundation      	0x9032e15b __CFRunLoopDoSources0 + 1563
20  com.apple.CoreFoundation      	0x9032bc1f __CFRunLoopRun + 1071
21  com.apple.CoreFoundation      	0x9032b0f4 CFRunLoopRunSpecific + 452
22  com.apple.CoreFoundation      	0x9032af21 CFRunLoopRunInMode + 97
23  com.apple.HIToolbox           	0x907650fc RunCurrentEventLoopInMode + 392
24  com.apple.HIToolbox           	0x90764eb1 ReceiveNextEventCommon + 354
25  com.apple.HIToolbox           	0x90764d36 BlockUntilNextEventMatchingListInMode + 81
26  com.apple.AppKit              	0x91a34135 _DPSNextEvent + 847
27  com.apple.AppKit              	0x91a33976 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
28  com.apple.AppKit              	0x919f5bef -[NSApplication run] + 821
29  com.resolume.avenue           	0x0029abe7 0x1000 + 2726887
30  com.resolume.avenue           	0x0014eab1 0x1000 + 1366705
31  com.resolume.avenue           	0x0014ed18 0x1000 + 1367320
32  com.resolume.avenue           	0x000193de 0x1000 + 99294
33  com.resolume.avenue           	0x00002a32 0x1000 + 6706
34  com.resolume.avenue           	0x00002959 0x1000 + 6489
Thread 1:  Dispatch queue: com.apple.libdispatch-manager
0   libSystem.B.dylib             	0x93cf9b42 kevent + 10
1   libSystem.B.dylib             	0x93cfa25c _dispatch_mgr_invoke + 215
2   libSystem.B.dylib             	0x93cf9719 _dispatch_queue_invoke + 163
3   libSystem.B.dylib             	0x93cf94be _dispatch_worker_thread2 + 240
4   libSystem.B.dylib             	0x93cf8f41 _pthread_wqthread + 390
5   libSystem.B.dylib             	0x93cf8d86 start_wqthread + 30
Thread 2:
0   libSystem.B.dylib             	0x93cd335a semaphore_timedwait_signal_trap + 10
1   libSystem.B.dylib             	0x93d00ea1 _pthread_cond_wait + 1066
2   libSystem.B.dylib             	0x93d4963c pthread_cond_timedwait + 47
3   com.resolume.avenue           	0x002920ea 0x1000 + 2691306
4   com.resolume.avenue           	0x0023036f 0x1000 + 2290543
5   com.resolume.avenue           	0x000adbe8 0x1000 + 707560
6   com.resolume.avenue           	0x0023090f 0x1000 + 2291983
7   com.resolume.avenue           	0x00230a83 0x1000 + 2292355
8   com.resolume.avenue           	0x00291c66 0x1000 + 2690150
9   libSystem.B.dylib             	0x93d00a19 _pthread_start + 345
10  libSystem.B.dylib             	0x93d0089e thread_start + 34
Thread 3:
5   com.resolume.avenue           	0x00230c87 0x1000 + 2292871
Thread 4:
Thread 5:
2   libSystem.B.dylib             	0x93d2fa28 pthread_cond_timedwait_relative_np + 47
3   com.apple.audio.CoreAudio     	0x965bd965 CAGuard::WaitFor(unsigned long long) + 219
4   com.apple.audio.CoreAudio     	0x965c0997 CAGuard::WaitUntil(unsigned long long) + 289
5   com.apple.audio.CoreAudio     	0x965be294 HP_IOThread::WorkLoop() + 1892
6   com.apple.audio.CoreAudio     	0x965bdb2b HP_IOThread::ThreadEntry(HP_IOThread*) + 17
7   com.apple.audio.CoreAudio     	0x965bda42 CAPThread::Entry(CAPThread*) + 140
8   libSystem.B.dylib             	0x93d00a19 _pthread_start + 345
9   libSystem.B.dylib             	0x93d0089e thread_start + 34
Thread 6:
Thread 7:
5   com.resolume.avenue           	0x000a0bf2 0x1000 + 654322
Thread 8:
5   com.resolume.avenue           	0x000811c5 0x1000 + 524741
Thread 9:
5   com.resolume.avenue           	0x00087194 0x1000 + 549268
Thread 10:
5   com.resolume.avenue           	0x0015a0e6 0x1000 + 1413350
Thread 11:
3   ...ple.CoreServices.CarbonCore	0x97e53465 TSWaitOnConditionTimedRelative + 242
4   ...ple.CoreServices.CarbonCore	0x97e531a3 TSWaitOnSemaphoreCommon + 511
5   ...ickTimeComponents.component	0x92ef091d ReadSchedulerThreadEntryPoint + 4698
6   libSystem.B.dylib             	0x93d00a19 _pthread_start + 345
7   libSystem.B.dylib             	0x93d0089e thread_start + 34
Thread 12:
0   libSystem.B.dylib             	0x93cf2286 select$DARWIN_EXTSN + 10
1   com.apple.CoreFoundation      	0x9036b82d __CFSocketManager + 1085
2   libSystem.B.dylib             	0x93d00a19 _pthread_start + 345
3   libSystem.B.dylib             	0x93d0089e thread_start + 34
Thread 13 Crashed:
0   com.resolume.avenue           	0x0015048a 0x1000 + 1373322
1   com.resolume.avenue           	0x00282b34 0x1000 + 2628404
2   com.resolume.avenue           	0x0015506c 0x1000 + 1392748
3   com.resolume.avenue           	0x001386cd 0x1000 + 1275597
4   com.resolume.avenue           	0x00136983 0x1000 + 1268099
5   com.resolume.avenue           	0x00138c37 0x1000 + 1276983
Thread 14:
Thread 15:
0   libSystem.B.dylib             	0x93cf8bd2 __workq_kernreturn + 10
1   libSystem.B.dylib             	0x93cf9168 _pthread_wqthread + 941
2   libSystem.B.dylib             	0x93cf8d86 start_wqthread + 30
Thread 16:
5   ...ple.CoreServices.CarbonCore	0x97eada50 AIOFileThread(void*) + 1127
Thread 13 crashed with X86 Thread State (32-bit):
  eax: 0x23e6e000  ebx: 0x00282976  ecx: 0x28cb3b00  edx: 0xfa350000
  edi: 0x00479c0f  esi: 0x00216346  ebp: 0xb0650d28  esp: 0xb064f590
   ss: 0x0000001f  efl: 0x00010286  eip: 0x0015048a   cs: 0x00000017
   ds: 0x0000001f   es: 0x0000001f   fs: 0x0000001f   gs: 0x00000037
  cr2: 0x23e6e000
Binary Images:
    0x1000 -   0x442fe5 +com.resolume.avenue 3.1.3 (3.1.3) <BC08BBEA-EF83-5431-D618-89F1752406D7> /Applications/Resolume Avenue 3.1.3/Avenue.app/Contents/MacOS/Avenue
  0x4c9000 -   0x515fff  com.apple.audio.midi.CoreMIDI 1.7 (42) <670CB7F9-AA00-86F3-6623-E1335F7AEA83> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
  0x53a000 -   0x554ffd +net.sourceforge.glew ??? (1.4.0) <BE16A519-E227-6149-FBF1-1011D1B3953F> /Applications/Resolume Avenue 3.1.3/Avenue.app/Contents/Resources/GLEW.framework/Versions/A/GLEW
  0x56c000 -   0x595fe3  com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) <7FFBD485-5251-776A-CC44-4470DD84112B> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
  0x5a6000 -   0x647fe7 +com.eltima.FlashInApp 2.0 (2.0.13.112) <7B3079B6-E00B-744D-87A6-88885E2B409A> /Applications/Resolume Avenue 3.1.3/Avenue.app/Contents/Frameworks/FlashInApp.framework/Versions/A/FlashInApp
 0x1f05000 -  0x1f08ff7 +SyzGL_Vignette ??? (???) <9644DE53-D39D-933D-1C55-46DD9B643A51> /Applications/Resolume Avenue 3.1.3/plugins/vfx/SyzGL_Vignette.bundle/Contents/MacOS/SyzGL_Vignette
 0x1f0d000 -  0x1f10ff7 +SyzGL_Vignette ??? (???) <9644DE53-D39D-933D-1C55-46DD9B643A51> /Applications/Resolume Avenue 3.1.3/plugins/vfx/SyzGL_Vignette.bundle/Contents/MacOS/SyzGL_Vignette
 0x1f15000 -  0x1f18ff7 +SyzGL_Vignette ??? (???) <9644DE53-D39D-933D-1C55-46DD9B643A51> /Applications/Resolume Avenue 3.1.3/plugins/vfx/SyzGL_Vignette.bundle/Contents/MacOS/SyzGL_Vignette
 0x1f1d000 -  0x1f20ff7 +SyzGL_Vignette ??? (???) <9644DE53-D39D-933D-1C55-46DD9B643A51> /Applications/Resolume Avenue 3.1.3/plugins/vfx/SyzGL_Vignette.bundle/Contents/MacOS/SyzGL_Vignette
0x1442e000 - 0x14431ff7 +SyzGL_Vignette ??? (???) <9644DE53-D39D-933D-1C55-46DD9B643A51> /Applications/Resolume Avenue 3.1.3/plugins/vfx/SyzGL_Vignette.bundle/Contents/MacOS/SyzGL_Vignette
0x14436000 - 0x14439ff7 +SyzGL_Vignette ??? (???) <9644DE53-D39D-933D-1C55-46DD9B643A51> /Applications/Resolume Avenue 3.1.3/plugins/vfx/SyzGL_Vignette.bundle/Contents/MacOS/SyzGL_Vignette
0x1452b000 - 0x1453cfe7  com.apple.DVCPROHDVideoDigitizer 1.3.2 (1.3.2) <6C25FC0F-D39E-2036-DB09-53046983ECE0> /Library/QuickTime/DVCPROHDVideoDigitizer.component/Contents/MacOS/DVCPROHDVideoDigitizer
0x14544000 - 0x1454eff7  com.apple.IOFWDVComponents 1.9.9 (1.9.9) <5B4E7BD7-EF5A-2F5C-DF8E-3D4A7B59F779> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
0x14595000 - 0x14597ff3  com.apple.LiveType.component 2.1.4 (2.1.4) <D60E2537-3B47-EA99-0077-6CE394378D07> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x1459d000 - 0x14601fe2  com.apple.LiveType.framework 2.1.4 (2.1.4) <1509B3FF-8573-CA6E-914A-6701F10C2159> /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
0x14f4c000 - 0x14fb1fe0  com.apple.DVCPROHDMuxer 1.3.2 (1.3.2) <94C8CA82-8E8D-F23F-0771-D065994A65D3> /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0x14fcb000 - 0x15007fe3  com.apple.QuickTimeFireWireDV.component 7.6.6 (1729) <E282B44A-AF33-668B-315A-1C18EC25682B> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x15013000 - 0x1503dffb  com.apple.QuickTimeIIDCDigitizer 7.6.6 (1729) <49F04AE5-9EEC-AF55-E80E-8669C0D31040> /System/Library/QuickTime/QuickTimeIIDCDigitizer.component/Contents/MacOS/QuickTimeIIDCDigitizer
0x15045000 - 0x15094fff  com.apple.QuickTimeUSBVDCDigitizer 2.5.9 (2.5.9) <D32CCD0F-97E4-D4A5-8171-00853F2DFF34> /System/Library/QuickTime/QuickTimeUSBVDCDigitizer.component/Contents/MacOS/QuickTimeUSBVDCDigitizer
0x1509f000 - 0x150a3ff3  com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) <C36F9194-6DB6-0AA8-4839-71191EEBAC65> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x150b2000 - 0x15225fe7  GLEngine ??? (???) <F0181B85-962E-508D-4912-056D87F8E96E> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x15257000 - 0x1565bfe7  libclh.dylib 3.1.1 C  (3.1.1) <FBDA4CAC-EBB3-2129-7EE3-E8E9381974C9> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x156a8000 - 0x156cbfe7  GLRendererFloat ??? (???) <65E1E174-28E0-3FA9-E391-504891B69818> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x18232000 - 0x18235ff7 +com.resolume.AVFFGLMask50 ??? (1.0) <24A86545-81F3-613B-6F05-F16EE8E9FCBA> /Applications/Resolume Avenue 3.1.3/plugins/vfx/AVFFGLMask50.bundle/Contents/MacOS/AVFFGLMask50
0x1823a000 - 0x1823dffb +com.resolume.AVFFGLRotateXMixer ??? (1.0) <9AC6BD0D-0B33-F25C-65C5-EE7E5B65BAA8> /Applications/Resolume Avenue 3.1.3/plugins/vfx/AVFFGLRotateXMixer.bundle/Contents/MacOS/AVFFGLRotateXMixer
0x18242000 - 0x18245ffb +com.resolume.AVFFGLRotateYMixer ??? (1.0) <CCB0FD2B-3413-6DE0-42F0-EFE870989A85> /Applications/Resolume Avenue 3.1.3/plugins/vfx/AVFFGLRotateYMixer.bundle/Contents/MacOS/AVFFGLRotateYMixer
0x1824a000 - 0x1824dffb +com.resolume.AVFFGLTimeSwitcher ??? (1.0) <DD30CC58-F3B0-8A40-375B-8C95E50D34A3> /Applications/Resolume Avenue 3.1.3/plugins/vfx/AVFFGLTimeSwitcher.bundle/Contents/MacOS/AVFFGLTimeSwitcher
0x18252000 - 0x18255ff3 +com.resolume.AVFFGLWipeDown ??? (1.0) <6D3AB25D-7487-88A1-0623-F98DF5EA1005> /Applications/Resolume Avenue 3.1.3/plugins/vfx/AVFFGLWipeDown.bundle/Contents/MacOS/AVFFGLWipeDown
0x1825a000 - 0x1825dff3 +com.resolume.AVFFGLWipeLeft ??? (1.0) <55212E17-EB76-CFFD-AC00-EE98DA045FF4> /Applications/Resolume Avenue 3.1.3/plugins/vfx/AVFFGLWipeLeft.bundle/Contents/MacOS/AVFFGLWipeLeft
0x18262000 - 0x18265ff3 +com.resolume.AVFFGLWipeRadial ??? (1.0) <401FBCBA-FE8E-3C2A-ED31-458FABA38B0C> /Applications/Resolume Avenue 3.1.3/plugins/vfx/AVFFGLWipeRadial.bundle/Contents/MacOS/AVFFGLWipeRadial
0x1826a000 - 0x1826dff3 +com.resolume.AVFFGLWipeRight ??? (1.0) <F8A3967B-3C6C-F979-EB10-17B0807B764E> /Applications/Resolume Avenue 3.1.3/plugins/vfx/AVFFGLWipeRight.bundle/Contents/MacOS/AVFFGLWipeRight
0x18272000 - 0x18275ff3 +AVFFGLWipeUp ??? (???) <55186590-D6B5-DE55-4580-E05DE058E2EA> /Applications/Resolume Avenue 3.1.3/plugins/vfx/AVFFGLWipeUp.bundle/Contents/MacOS/AVFFGLWipeUp
0x1827a000 - 0x1827dffb +com.resolume.AVFFGLZoomMixer ??? (1.0) <7D539D08-C5EB-0A38-E306-EF2EC5E5E9BE> /Applications/Resolume Avenue 3.1.3/plugins/vfx/AVFFGLZoomMixer.bundle/Contents/MacOS/AVFFGLZoomMixer
0x18282000 - 0x18285ffb +com.resolume.AVFFGLZoomMixerOut ??? (1.0) <FF9D250F-342F-8C9F-501A-8742198E265B> /Applications/Resolume Avenue 3.1.3/plugins/vfx/AVFFGLZoomMixerOut.bundle/Contents/MacOS/AVFFGLZoomMixerOut
0x1828a000 - 0x1828dff3 +com.resolume.FFGLAdd ??? (1.0) <41657423-5C01-F750-2C5E-B79DB2E0BB4D> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLAdd.bundle/Contents/MacOS/FFGLAdd
0x18292000 - 0x18295ff3 +com.resolume.FFGLAdd50 ??? (1.0) <6A9FACD8-C4DA-D786-DAE5-4A8AA4A47314> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLAdd50.bundle/Contents/MacOS/FFGLAdd50
0x1829a000 - 0x1829dff3 +com.resolume.FFGLAddMaskUtility ??? (1.0) <E89E8C6E-0709-DBB2-41AB-3D2C9102D3D7> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLAddMaskUtility.bundle/Contents/MacOS/FFGLAddMaskUtility
0x182a2000 - 0x182a5ff3 +com.resolume.FFGLAlpha ??? (1.0) <EB0CACDD-7E37-A8B6-C2BC-60651217181F> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLAlpha.bundle/Contents/MacOS/FFGLAlpha
0x182aa000 - 0x182adff3 +com.resolume.FFGLBurn ??? (1.0) <9C4A2385-BB3E-5D37-6579-0D472BD02F2A> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLBurn.bundle/Contents/MacOS/FFGLBurn
0x182b2000 - 0x182b5fff +com.resolume.FFGLDarken ??? (1.0) <CE9AC9FA-EA4F-C230-7FC8-507D00C8E471> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLDarken.bundle/Contents/MacOS/FFGLDarken
0x182ba000 - 0x182bdff3 +com.resolume.FFGLDifference ??? (1.0) <B61303E1-9D44-89BF-EFB2-91C18D7C881C> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLDifference.bundle/Contents/MacOS/FFGLDifference
0x182c2000 - 0x182c5ff3 +com.resolume.FFGLDifferenceInverse ??? (1.0) <29D033DF-3372-D598-F057-E00C094E5B74> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLDifferenceInverse.bundle/Contents/MacOS/FFGLDifferenceInverse
0x182ca000 - 0x182cdff3 +com.resolume.FFGLDodge ??? (1.0) <2CC1ABAE-386D-9E21-4041-1ED197666DF0> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLDodge.bundle/Contents/MacOS/FFGLDodge
0x182d2000 - 0x182d5ff3 +com.resolume.FFGLHardLight ??? (1.0) <D98F32DA-79EC-BE15-FF7F-A351CBB14068> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLHardLight.bundle/Contents/MacOS/FFGLHardLight
0x182da000 - 0x182ddff7 +com.resolume.FFGLLighten ??? (1.0) <1A8DB34C-291B-4113-8B51-70AB6917391D> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLLighten.bundle/Contents/MacOS/FFGLLighten
0x182e2000 - 0x182e5ff7 +com.resolume.FFGLLighten50 ??? (1.0) <F217ED01-D61F-3F99-4CFA-7C70B147CF05> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLLighten50.bundle/Contents/MacOS/FFGLLighten50
0x182ea000 - 0x182edff3 +com.resolume.FFGLLumaIsAlpha ??? (1.0) <BB2A7AEB-0D81-B21F-B487-FEEC17E28D15> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLLumaIsAlpha.bundle/Contents/MacOS/FFGLLumaIsAlpha
0x182f2000 - 0x182f5ff3 +com.resolume.FFGLLumaKey ??? (1.0) <C4D1955E-592E-91A7-66F6-AF42F6548631> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLLumaKey.bundle/Contents/MacOS/FFGLLumaKey
0x18700000 - 0x18703ff3 +com.resolume.FFGLLumaKeyInverse ??? (1.0) <DD988BA1-92AC-9C64-C128-054DBAB07DE4> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLLumaKeyInverse.bundle/Contents/MacOS/FFGLLumaKeyInverse
0x18708000 - 0x1870bff3 +com.resolume.FFGLMultiply ??? (1.0) <BE7838E9-8F21-AAD8-CB77-E627386FC0C1> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLMultiply.bundle/Contents/MacOS/FFGLMultiply
0x18710000 - 0x18713ff7 +com.resolume.FFGLRGBASwitch ??? (1.0) <15A22F40-D41A-F51B-47E8-4D6A400A0E0D> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLRGBASwitch.bundle/Contents/MacOS/FFGLRGBASwitch
0x18718000 - 0x1871bff3 +com.resolume.FFGLScreen ??? (1.0) <05CE1E61-9176-F796-5B95-96879A611D3C> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLScreen.bundle/Contents/MacOS/FFGLScreen
0x18720000 - 0x18723ff3 +com.resolume.FFGLSoftLight ??? (1.0) <9BE5EF49-EC2F-8F0C-A4E1-8727D384FEA6> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLSoftLight.bundle/Contents/MacOS/FFGLSoftLight
0x18728000 - 0x1872bff3 +com.resolume.FFGLSubtract ??? (1.0) <AFD848B3-4F22-53B4-F41A-0956939478F8> /Applications/Resolume Avenue 3.1.3/plugins/vfx/FFGLSubtract.bundle/Contents/MacOS/FFGLSubtract
0x18730000 - 0x18736ffb  com.apple.audio.AppleHDAHALPlugIn 1.8.4 (1.8.4fc3) <89AF8F46-15E4-2066-BDDB-05E92C1368D4> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x3e000000 - 0x3e046ff7  com.apple.glut 3.4.4 (GLUT-3.4.4) <DF15FD36-E1F5-D745-1BF6-DD3AEA2897E4> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
0x70000000 - 0x700caffb  com.apple.audio.units.Components 1.6.1 (1.6.1) <AEC44B68-A209-4093-36B0-7B740361249B> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8f12c000 - 0x8f7b4fff  com.apple.GeForceGLDriver 1.6.10 (6.1.0) <EFC80A22-4F62-3DFC-A391-738B2A8A4E56> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
0x9002d000 - 0x9011fff7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7482933B-4AF6-ED55-AD72-4FBD1E134958> /usr/lib/libcrypto.0.9.8.dylib
0x90159000 - 0x90159ff7  com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9015b000 - 0x90287fff  com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <F0D7256E-0914-8E77-E37B-9720430422AB> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x90288000 - 0x902ccff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x902ef000 - 0x90468ffb  com.apple.CoreFoundation 6.6.1 (550.19) <1E97FB1E-9E42-B8EB-E463-5C75315FDA31> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x904e0000 - 0x90572fe3  com.apple.print.framework.PrintCore 6.2 (312.5) <7729B4D7-D661-D669-FA7E-510F93F685A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x90573000 - 0x905b6ff7  libGLU.dylib ??? (???) <CE02968E-930D-E63B-7B21-B87205F8B19A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x905b7000 - 0x905c8ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <7A3862F7-3730-8F6E-A5DE-8E2CCEA979EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x90665000 - 0x90681fe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x90682000 - 0x9072ffe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
0x90730000 - 0x90a54fef  com.apple.HIToolbox 1.6.2 (???) <F5F99E78-5377-DD54-6138-9FC84467F938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x90a5a000 - 0x90dc1ff7  com.apple.QuartzCore 1.6.1 (227.18) <8A65F233-4C77-BA7C-5DDA-2423F5C1B7A1> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x90e03000 - 0x90e42ff7  com.apple.ImageCaptureCore 1.0.1 (1.0.1) <A03C5D7E-54CD-D56D-E120-9B35EBC9D8F1> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x9104a000 - 0x91074ff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x910f4000 - 0x91158ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x91159000 - 0x91194feb  libFontRegistry.dylib ??? (???) <F50A60E1-3757-D007-A20D-A5504C17334C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x91195000 - 0x9119bff7  com.apple.DisplayServicesFW 2.2.2 (251) <D8BB3A1F-29C7-A957-C781-794CC9550525> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x91378000 - 0x914bafe3  com.apple.QTKit 7.6.6 (1729) <1EC021FB-AB8F-F8BF-0434-78C0A7B78EB2> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x914bb000 - 0x9163dfe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <96A45E03-2B29-83EB-0FC6-2C932E398722> /usr/lib/libicucore.A.dylib
0x91657000 - 0x91662ff7  libCSync.A.dylib 543.33.0 (compatibility 64.0.0) <F914F427-98EA-98BC-923D-47274A90D441> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x91663000 - 0x916a1ff7  com.apple.CoreMedia 0.484.5 (484.5) <35725D22-4549-5568-8E8C-62E0AD0E90F7> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x9189b000 - 0x918a2ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6BF89127-C18C-27A9-F94A-981836A822FE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x918a3000 - 0x9196dfef  com.apple.CoreServices.OSServices 357 (357) <764872C3-AE30-7F54-494D-4BA3CE4F4DFB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9196e000 - 0x9198ffe7  com.apple.opencl 12.1 (12.1) <1BCA4F60-E612-5C1B-EF50-A810D70CDF05> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x91990000 - 0x919ebff7  com.apple.framework.IOKit 2.0 (???) <69E4FE93-376C-565E-650F-04FAD213AA24> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x919ec000 - 0x922cbff7  com.apple.AppKit 6.6.5 (1038.29) <E76A05A6-27C6-DA02-0961-5C8EEDC5F0A7> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x922cc000 - 0x9233bff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9233c000 - 0x9233dff7  com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <959DFFAE-A06B-7FF6-B713-B2076893EBBD> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9233e000 - 0x924faff3  com.apple.ImageIO.framework 3.0.2 (3.0.1) <CB39B067-58B8-70DB-3E40-160604664A6D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x924fb000 - 0x9257bfeb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9257c000 - 0x925c9feb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x925ca000 - 0x925caff7  com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x925cb000 - 0x9260cff7  libRIP.A.dylib 543.33.0 (compatibility 64.0.0) <C6E50C7E-EBEE-32AF-FF07-8E325E21A838> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x92621000 - 0x92652ff7  libGLImage.dylib ??? (???) <AF110892-B10A-5B61-F898-21FB2BCE63BF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x92653000 - 0x9270cfe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
0x9270d000 - 0x92819ff7  libGLProgrammability.dylib ??? (???) <CA0A975B-2BEE-44E7-CFA6-8105CFE6FE00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x928cf000 - 0x928e3ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x928e4000 - 0x92935ff7  com.apple.HIServices 1.8.0 (???) <10C85B88-C6AF-91DB-2546-34661BA35AC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x92936000 - 0x93887fe7  com.apple.QuickTimeComponents.component 7.6.6 (1729) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x938a6000 - 0x938bafe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x938bb000 - 0x93cd1ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x93cd2000 - 0x93e77feb  libSystem.B.dylib 125.0.1 (compatibility 1.0.0) <06A5336A-A6F6-4E62-F55F-4909A64631C2> /usr/lib/libSystem.B.dylib
0x93e78000 - 0x93e7fff3  com.apple.print.framework.Print 6.1 (237.1) <97AB70B6-C653-212F-CFD3-E3816D0F5C22> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x93e8b000 - 0x93eafff7  libJPEG.dylib ??? (???) <EDA86712-F49C-760C-BE55-9B899A4A5D1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x93edc000 - 0x93f85ff7  com.apple.CFNetwork 454.9.4 (454.9.4) <2F8B5BA5-099F-6CDA-F500-4CA188BBCDBC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x93f86000 - 0x93f96ff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x93f97000 - 0x94047ff3  com.apple.ColorSync 4.6.3 (4.6.3) <68B6A1B9-86CF-0C5A-7D63-56ED4BB2EB5B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x94048000 - 0x94085ff7  com.apple.SystemConfiguration 1.10.2 (1.10.2) <830FED9E-3E24-004C-35D5-2C1273F79734> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x94086000 - 0x940b9ff7  com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x94132000 - 0x941e0ff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x941e1000 - 0x942bcfe7  com.apple.DesktopServices 1.5.5 (1.5.5) <ECEDFDF2-C40E-8DF0-F8FC-249CCA762E62> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x942bd000 - 0x943befe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
0x943bf000 - 0x94405ff7  libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
0x94406000 - 0x9440cff7  libCGXCoreImage.A.dylib 543.33.0 (compatibility 64.0.0) <DD359830-97D4-0CD4-8666-DFE450E8D633> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x9442a000 - 0x9442aff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x94471000 - 0x94653fff  com.apple.imageKit 2.0.3 (1.0) <56AE34CD-4406-8AA2-DDBF-DBF902BD0E0A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x94654000 - 0x94658ff7  IOSurface ??? (???) <4B825ADA-8DBE-6BA2-1AB3-307D2C3AFCA8> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x94659000 - 0x9467ffff  com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9468d000 - 0x946a5ff7  com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x946a6000 - 0x946fcff7  com.apple.MeshKitRuntime 1.1 (49.2) <F1EAE9EC-2DA3-BAFD-0A8C-6A3FFC96D728> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
0x9473e000 - 0x94798fe7  com.apple.CorePDF 1.1 (1.1) <E4608FF6-A27D-7DFC-5620-D86762502AC0> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x94799000 - 0x94807ff7  com.apple.QuickLookUIFramework 2.2 (327.4) <5B6A066B-B867-D3A3-BDEE-3D68FA5385B4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x94808000 - 0x94827fe3  libexpat.1.dylib 7.2.0 (compatibility 7.0.0) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
0x94828000 - 0x9486cfe7  com.apple.Metadata 10.6.3 (507.8) <53BB360A-1813-170D-827F-C1863EF15537> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9486d000 - 0x94888ff7  libPng.dylib ??? (???) <929FE8EE-277D-F6EB-D672-E6F4CEBF1504> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x94889000 - 0x94889ff7  com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9488a000 - 0x9488dff7  libCoreVMClient.dylib ??? (???) <98CB96B1-85FE-25AF-AB19-ED061912FC3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x948b9000 - 0x94969fe3  com.apple.QuickTimeImporters.component 7.6.6 (1729) <6C2372BA-69D9-E713-902F-95E16FD18EFD> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x949e1000 - 0x94a79fe7  edu.mit.Kerberos 6.5.9 (6.5.9) <73EC847F-FF44-D542-2AD5-97F6C8D48F0B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x94a7a000 - 0x94bfafeb  com.apple.MediaToolbox 0.484.5 (484.5) <6996E5E1-18B6-C734-8335-FE43670C1F9C> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x94c2e000 - 0x94d65ff7  com.apple.CoreAUC 6.04.00 (6.04.00) <0551FB8D-0894-B40B-B924-4AF51E3648AF> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x94d66000 - 0x94d6aff7  libGFXShared.dylib ??? (???) <286F466C-2856-B579-B87F-4E9A35C80263> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x94d92000 - 0x94d92ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x94d93000 - 0x94d9cff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x94e0a000 - 0x94e16ff7  libkxld.dylib ??? (???) <13F26BB6-C2F7-9D74-933E-09AD8B509ECD> /usr/lib/system/libkxld.dylib
0x94e17000 - 0x94ebfffb  com.apple.QD 3.35 (???) <B80B64BC-958B-DA9E-50F9-D7E8333CC5A2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x94ec0000 - 0x94ec2ff7  com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x94ec3000 - 0x94f34ff7  com.apple.AppleVAFramework 4.8.11 (4.8.11) <BDDDFA36-4B53-4B57-B3D4-427DA8226A80> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x94f35000 - 0x95768fe7  com.apple.WebCore 6531.22 (6531.22.7) <952A0D34-63F5-F7F7-D6E5-D0AD78002F89> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x95769000 - 0x9576cffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x9576d000 - 0x957efffb  SecurityFoundation 36840.0.0 (compatibility 1.0.0) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x957f0000 - 0x95826fff  libtidy.A.dylib ??? (???) <DDFAB560-3883-A6A2-7BDD-D91730982B48> /usr/lib/libtidy.A.dylib
0x95827000 - 0x9582bff7  libGIF.dylib ??? (???) <03880BA1-7A86-0F2B-617A-C66B1D05DD70> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9582c000 - 0x9588dfe7  com.apple.CoreText 3.1.0 (???) <1372DABE-F183-DD03-03C2-64B2464A4FD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x9588e000 - 0x9588fff7  com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x95890000 - 0x9589dff7  com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x9589e000 - 0x958e7fe7  libTIFF.dylib ??? (???) <E45B169E-253E-E865-1501-97777D2702F2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x958e8000 - 0x958e8ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x95902000 - 0x9599ffe3  com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x959a0000 - 0x959e3ff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x959e4000 - 0x95e19ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x95e1a000 - 0x95e1bff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x95e1c000 - 0x95e27ff7  libGL.dylib ??? (???) <EAD85409-9036-831B-C378-E50780305DA6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x95e28000 - 0x95e2dff7  com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x95e2e000 - 0x95f09ff7  com.apple.DiscRecording 5.0.3 (5030.4.2) <CC86EBA6-5E48-32C0-77AE-81479DFF6D4A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x9623c000 - 0x96319ff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9631a000 - 0x9632cff7  com.apple.MultitouchSupport.framework 204.12.1 (204.12.1) <6BB58E90-21FA-C491-F0E4-54B69CCDBBC0> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x9632d000 - 0x96337ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x96338000 - 0x9643afef  com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
0x9643b000 - 0x9651fff7  com.apple.WebKit 6531.22 (6531.22.7) <87C81D6F-77B1-C517-93E6-5DEF214326A7> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x9659d000 - 0x96617fef  com.apple.audio.CoreAudio 3.2.2 (3.2.2) <1F97B48A-327B-89CC-7C01-3865179716E0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x96618000 - 0x96670fe7  com.apple.datadetectorscore 2.0 (80.7) <A40AA74A-9D13-2A6C-5440-B50905923251> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x966ba000 - 0x966bdfe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x966be000 - 0x966d3fff  com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x966d4000 - 0x9673efe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x9678d000 - 0x969efff3  com.apple.security 6.1.1 (37594) <1AC07F75-7E27-9662-21DA-B05DFF047B26> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x96a9f000 - 0x96a9fff7  com.apple.quartzframework 1.5 (1.5) <CEB78F00-C5B2-3B3F-BF70-DD6D578719C0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x96bbf000 - 0x96bcdfe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <82B2C254-6F8D-7BEA-4C18-038E90CAE19B> /usr/lib/libz.1.dylib
0x96bde000 - 0x96c0fff3  libTrueTypeScaler.dylib ??? (???) <4C189FCA-A210-7255-8F70-38DF9D19F877> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x96c10000 - 0x96c52ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x96c53000 - 0x96c59fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x96c5c000 - 0x96c5eff7  libRadiance.dylib ??? (???) <9358E1EF-F802-B76E-8E23-2D0695787CFB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x96c5f000 - 0x96c69fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x96c6f000 - 0x96c72ff7  libCGXType.A.dylib 543.33.0 (compatibility 64.0.0) <69BE578C-A364-A150-35E3-53EE00F56F05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x96c73000 - 0x96c83ff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x96c84000 - 0x96ca4fe7  libresolv.9.dylib 40.0.0 (compatibility 1.0.0) <03019DD7-993D-AC88-6636-179F92F315C4> /usr/lib/libresolv.9.dylib
0x96ca5000 - 0x96d40ff7  com.apple.ApplicationServices.ATS 4.1 (???) <22FCDB9B-B588-D602-3991-26A2E3C51E6E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x96d41000 - 0x9705dfe7  com.apple.RawCamera.bundle 2.3.2 (516) <9C1C6ED1-C392-6779-0D34-47E62EAF93BA> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x970a6000 - 0x970ceff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x970cf000 - 0x971fdfe7  com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x971fe000 - 0x9721cff7  com.apple.CoreVideo 1.6.1 (45.4) <E0DF044D-BF31-42CE-B690-FD1FCE07E64A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9721d000 - 0x9721dff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9721e000 - 0x97449ff3  com.apple.QuartzComposer 4.1 (156.13) <FE0BF06B-8D32-C712-7CCD-63D8918B8B6D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x97613000 - 0x9768cff7  com.apple.PDFKit 2.5.1 (2.5.1) <CEF13510-F08D-3177-7504-7F8853906DE6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x9768d000 - 0x976affef  com.apple.DirectoryService.Framework 3.6 (621.3) <05FFDBDB-F16B-8AC0-DB42-986965FCBD95> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x976e0000 - 0x97707ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x97708000 - 0x978a6feb  com.apple.JavaScriptCore 6531.22 (6531.22.5) <3FB9AF5B-17DD-D4C8-C7B1-4F79B404496E> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x978a7000 - 0x97b17ffb  com.apple.Foundation 6.6.2 (751.21) <DA7A173A-4435-ECD6-F4AF-977D722FD2F7> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x97e0c000 - 0x9812cfeb  com.apple.CoreServices.CarbonCore 861.6 (861.6) <D3D5D9F1-01ED-DCAD-6AA9-4ABE60C7A112> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9812d000 - 0x9891c537  com.apple.CoreGraphics 1.543.33 (???) <C57E2964-80AF-6346-6D3E-23AED9D26977> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9891d000 - 0x98963ffb  com.apple.CoreMediaIOServices 130.0 (1035) <397101F4-BA80-C8C2-F816-E2FBE5E15D4F> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x98964000 - 0x98e21ffb  com.apple.VideoToolbox 0.484.5 (484.5) <DA9B4FA8-B91C-43AC-1D84-0BFF46BB5BCE> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x98e22000 - 0x98e57ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <458E819A-4E3F-333E-28CE-671281B318D3> /usr/lib/libcups.2.dylib
0x98ed9000 - 0x98ee3ff7  com.apple.HelpData 2.0.4 (34) <9128FFEB-0F6C-B273-FCF4-D87A20227345> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x98ef2000 - 0x98fa8fef  libFontParser.dylib ??? (???) <FA6B6B8B-1E3C-8EEB-DD0D-6C7482353179> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x98fa9000 - 0x98fd9ff7  com.apple.MeshKit 1.1 (49.2) <ECFBD794-5D36-4405-6184-5568BFF29BF3> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
0x98fe2000 - 0x992dbfef  com.apple.QuickTime 7.6.6 (1729) <4C99ED7D-5A4B-E41E-602D-2D01A99168CD> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x992dc000 - 0x9934ffff  com.apple.iLifeMediaBrowser 2.1.5 (368) <30261504-7533-5424-DD15-32739DED6FB0> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0x995dd000 - 0x9962dff7  com.apple.framework.familycontrols 2.0.1 (2010) <50E74916-19A5-F2FC-AB57-76F2C8DDF0A7> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x9962e000 - 0x9966cff7  com.apple.QuickLookFramework 2.2 (327.4) <88A59C42-A200-FCB6-23EC-E848D0E14963> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x9966d000 - 0x9967bff7  com.apple.opengl 1.6.7 (1.6.7) <3C529790-DEE9-AC27-A879-806E4C23323C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9967c000 - 0x9967cff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0xbb100000 - 0xbb103fe7  libLatinSuppConverter.dylib 49.0.0 (compatibility 1.0.0) <59D12876-5E0C-803C-EC99-832012CF3416> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <06A5336A-A6F6-4E62-F55F-4909A64631C2> /usr/lib/libSystem.B.dylib
Model: MacBookPro5,4, BootROM MBP53.00AC.B03, 2 processors, Intel Core 2 Duo, 2.53 GHz, 4 GB, SMC 1.49f2
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.91.27)
Bluetooth: Version 2.3.1f4, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: FUJITSU MJA2250BH FFS G1, 232,89 GB
Serial ATA Device: MATSHITADVD-R   UJ-868
USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8507, 0x24400000
USB Device: LaCie Hard Drive USB, 0x059f  (LaCie), 0x0951, 0x26200000
USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0x26500000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x0237, 0x04600000
USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x04500000
USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000
USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8213, 0x06110000
Kind regards , Dirk Willem Wonnink
						Crash on macbook pro
Re: Crash on macbook pro
Hey Dirk
Sorry to hear you're experiencing problems and thanks very much for the logs. Could you please send an email to support[at]resolume[dot]com with the Resolume logfile: /Users/[username]/Library/Logs/Resolume Avenue 3 log.txt and if possible the composition which is causing the trouble?
That way we have all the relevant info in one place and we can hopefully solve the issue more quickly!
