Evolution UC 33 trouble
ju_
Post by ju_ »
I just bought a Evolution UC 33. Everything is working fine, except the controlling of the effect parametres, the one from the active layer, or even for each layer separatly.
Did any one had the same probleme?
thanks
Jeremy_
Post by Jeremy_ »
Hi jun,
What is your config ?
OS, etc...
Are you able to change the intensity of an effect with one of the controller ?
(do you speak french)
DinkyToys_
Post by DinkyToys_ »
Hi. I have the X-Sessions.
Did you make you're own setup-controls with their U-Media program or something?
And did you setup the midi in Resolume?
ju_
Post by ju_ »
Well, I'm using a laptop with XP and resolume 1.5 and the UC-33 connected via usb.
I setup the midi in resolume. I can control almost everything i want, except the parameters (1,2,3,4) of an effects. Actually the global effect parametres are on the sliders, thier working fine, but the effects parametres of each layer are on 12 other rotary knobs, and they do not work!
Only the first parameter works when i use it on a effect who has only one parametre.
Does any one has an idea??
thanks
P.S. Yes I do speak french, Is my english that bad? ;-)
JUL35_
Post by JUL35_ »
Hello, I'm having the same problem with my uc16, have you resolved your? because I've tried with another midi controler and the effects of the layers still don't work...
thanks
david_
Post by david_ »
iam using uc 33 and its working perfectly... i can control every parameter.
Another question is that resolume has many bugs that should be point, maybe...
ju_
Post by ju_ »
No, I did not find a solution.
David, May you explain me how did you configure your UC33? Did you put your 4 effects parameters of the 3 layers on 3x4 rotary knobs, like I explained?
And their working fine ? With every effects ? even with the “plug’-in” you may install ?
lore_
Post by lore_ »
do u know where can i buy A similar object send hand working at maximum 100 euro?
