Installation error win 7 x64
dbiz
Post by dbiz »
:shock: hi, on my pc with windows 7 x64 and a nVidia 9600GT seems to be an error in the install. After asking for the installation dir an error occurred with the message "non implemented" for both new exe, installer and dvx codec... semm to be a windows 7 error... previous release 3.1.3 works fine .... what can i do??
Re: Installation error win 7 x64
Hey Dbiz
Thanks for making a new topic for this!
Try deleting or moving any files relating to R3.1.3, and then installing in the default install directory. If the problems persist, please contact us at support[at]resolume[dot]com.
dbiz
Post by dbiz »
:( did not work =( even the uninstaller of the 3.1.3 says not implemented ... i try also moving files from : ( programfiles x86 , documents, and appdata/roaming ... damn
For future travellers:
As Bart mentioned in the original thread, there was a problem with the installer, which is now fixed.
