midi
why ?_
Post by why ?_ »
Is anyone able to control the effect parameter 1,2,3,4 of layer 1,2,3 with dedicated midi controllers?
I got a UC 33 controller, everything is working fine, except effect parameters for the layers! The 4 global parameter are working well.
Is it a bug in resolume?
Thanks.
huh? since you can not assign a effect to a layer there is also no midi controlled parameters ...
why ?_
Post by why ?_ »
So, that controller menu in "preferences > midi mapping > controllers" with
Effect param 1 : layer 1
Effect param 2 : layer 1
Effect param 3 : layer 1
Effect param 4 : layer 1
Effect param 1 : layer 2
Effect param 2 : layer 2
Effect param...
Does NOT work ??
Thanks.
flip_
Post by flip_ »
Hi Why
You can trigger effect params with MIDI on the effect loaded in the channel. If the channel is active in a layer you can use the UC33 to control the params you assigned of the channel on the fly.
One minor thing, the midi mapping of layer 1 contains a bug: if you program the UC33 by moving a control in the midi effect field of resolume, the control value is set. However, when you use the UC33 control a different midi signal (the original value - 1) is interpreted by resolume (!!). You have to adjust this on your UC33 by changing the midi send signal value minus 1.
boozo_
Post by boozo_ »
yo...
what i can say is that the parameters work very well with my doepfer pocket dial... and midi files...
gr33tz 8)
