Hi all.
there is a problem. In the interface, Resolume 2.x only 4 parameters in the effects.
how to use freeframes with Num Parameters: 8
Freeframe 1.0 and more Parameters
Re: Freeframe 1.0 and more Parameters
you talk about "rparameters? parameters that were in previous versions the avenue?
In this case I think that in those versions could only handle up to 4 variables. However, from the version number of variables avenue is indefinite according to what the manual says the program
As far as I can remember Resolume 2.x only supports (the first) 4 parameters of FreeFrame plugins. But you can somehow work around by "rewiring" the parameter's order using FFRend (see http://ffrend.sourceforge.net/ and Google of course)
- hope that helps
