non square vs square pixles
kyle_
Post by kyle_ »
i was wondering ... why does resolume only output resolutions that are square... i mean does anyone play out on a computer monitor... i sure dont .. that means its ntsc (or pla) not vga right...
what does the tv out of computer cards output... ntsc if its a real tv out... and the pixel arent square on a ntsc monitor... and the arent if your using the ntsc input on a projector... someone use flash and make a circle... its not a circles when projected through the ntsc input on a projector is it?....
and then this brings up questions about resolumes intrepreting...
im looking onto totally redesigning my video setup and thinking about getting the matrox parhia for its realtime aftereffects output to ntsc... but i want to understand all this before i buy a new card....
whiterabbit_
Post by whiterabbit_ »
Sounds like you are from the ntsc zone ,the ntsc or pal(not pla) is going out through your vga out into the beamer that i assume you use for your shows.
If you're going to get Pariah and your puter is fast enuff just work from full avis and you get all the details you like ....works for me at least,you gotta turn of anything else you don't need and run only resolume ant it worx fine....
whiterabbit_
Matrox Pharelia not pariah ,ha, nice change ...
