2 external audio questions
coz3r
Post by coz3r »
I looked in the manual but manuals tend to excite my ADD so I apologize if my questions are obvious!
1. Is it possible to have an event triggered when the volume hits a certain level? For instance toggling a clip to either move forward or backwards as the beat hits.
2. is there a better way to switch from basic control to external control on parameters? The dropdown menu is somewhat of a hurdle when youre trying to switch on the fly. I tried to map it to midi but without luck.
Thanks for your help!!
deflost
Re: 2 external audio questions
Post by deflost »
hallo, i have the same questions too.
is there any reason, why none anser these?
westfernsehen, leipzig
Hey there!
At the moment, no. Features like this, although we can see the functionality, don't really fit into the overall workflow of Avenue. For this sort of functionality, you usually are better off in a programming environment like Max, Flash or Processing.
These switches can not be controlled externally. You could however have multiple copies of a clip, each set to its own animator, which could then be triggered by midi.
I hope that answers your questions!
