What do you use with knobs?
banicos
Post by banicos »
Hi!
I'm start using a m-audio x-session controller. This controller has 12 knobs, but i am only using 6 of them for effects. What could i use fot the other knobs?
Any sugestion?
Many Thanks!
twitchdoktor
Re: What do you use with knobs?
Post by twitchdoktor »
if you use different blend modes, you may map the knob to switch between the three mode-selections showing on a layer. That way you could put your three most-used on a layer and select between them quickly.
banicos
Post by banicos »
I don't know what is the Blend Mode eheh! i will read the manual and then i say something here.
