masks and effects
MORS TV
masks and effects
Post by MORS TV »
I have a lot of issues when using effects, when i have applied a mask to a layer. Basicly the effect, for example the point grid, is overruling my mask and the output is outside the masked area's. I have the same problem when mapping objects with keystone in a layer. Is this a known issue? and are there workaround?
Ciao,
MORS TV
sleepytom
Re: masks and effects
Post by sleepytom »
its to do with the order the effects are processed in.
One workaround is to mask / keystone at the layer level rather than on individual clips.
