Recording
oblivionrpg
Recording
Post by oblivionrpg »
I know Avenue 3.1.3 isn´t a final one, but why do you have recording in it when it is impossible to use (well for larger than 4 minutes sets anywat). I usually use fraps and then compress it, but today I didn´t have much time, so I tried your recording. Well It would have been easier to use fraps.. Every time I recorded something longer than 4 mins. it froze. And I need like 60 mins, set... Don´t get me wrong I love your sofrware but this just makes me tear my hear of my had...
funkyant
Re: Recording
Post by funkyant »
So why not just install the update to 3.2?
Re: Recording
Although we always recommend using the latest version, please be aware that even on 3.2, the max recording time will be limited by your system resources.
HerrNieDa
Re: Recording
Post by HerrNieDa »
if you really wanna record your output smooth the best way is an external video capture device, whatever it is, a dvd recorder, dv-cam with av-in, extra pc with tv-capture cards etc...
