How to Video Mapping
banicos
Post by banicos »
I've bought a Projector. I want to start making video mapping.
There's any manual to Video Mapping? Can i do video mapping with resolume?
Re: How to Video Mapping
Hey Banicos
Yes, you can do video mapping with Resolume. The two easiest ways are the following:
1. Use the Keystone effects (Keystone, Keystone Crop and Keystone Mask) to map or mask your layers to any rectangular or semi rectangular surface.
2. Use the masks on the layer or composition level to mask the areas you don't want to project on. You can use Photoshop or a similar application to create very accurate masks. Check this video for more info: http://www.youtube.com/watch?v=eccZE1dd6PQ
We are working on a video tutorial for this, but for now experimenting is the way go!
Good luck!
banicos
Post by banicos »
Hi!
Great helpful!
