dv in problems
whiterabbit_
Post by whiterabbit_ »
I'm using a vx1000 for livefeed and encounter problems like; after a while of having the livestream coming in loading efects on other clips might be possible but rightclick to chage parameters esults in an empty box and from then on it's going downhill till the final crash.
my system should be able to cope with it 2.4ghz P4 1gig ram....
anybody encounters simmilar problems or evenetter knows a solution.?
cheers
WR
what resolution does the dv input?
themadesthatter_
Post by themadesthatter_ »
having kind of a problem with DV in as well:
picture is flipped upside down!
anyone knows why?
regards,
mad
julian_
Post by julian_ »
what resolution...dunno how can i check that, didn't know i can control that.
I'll check but what resolution should it be for ideal situation?
SuperficiaL_
Post by SuperficiaL_ »
hi Julian,
when u doubleclick the generator u see a menu on the left bottom of your screen. there are all the settings u need to change for efficient dv in.
the best resolution is the resolution u are outputting in.
less would be ugly more would be a waist of cpu power...
and Mad, i think if u try to drag the generator to one of the 20 slots the image will be up right.
i heard if u use the freeframe-capture thing the image is upside down...
God luck, SuperficiaL
SuperficiaL_
Good luck that is....
vj.dexter_
Post by vj.dexter_ »
Resolume have problems with windows media player 9 and direct x 9 !!!
b'_
Post by b'_ »
ah, is this why my pc keeps freezing...???
Does anybody know what media player and direct x version works best with resolume? Or any other remedy against freezing all the time??? P 4 2.66 GHz, 1 gb RAM. Works fine with premiere 6.5. but can't handle resolume...
Also 'Device controll' doesn't find my canopus DVRaptor-RT videocard.
aargh, i would love to work with it when it works; it looks great! (now using the free-trial version: already 7 day's trying to let it run.. ) I want to work with it !!!
julian_
Post by julian_ »
cheers superficial I'll check that
julian_
Post by julian_ »
Is there a way to fix the deinterlace problem at all, still cam live in is fine but moving it around and when people move too fast results in big fat stripes , so big it even mite be something else but deinterlacing, the deinterlacing plug doesn't make a change.............
any idea floating out there to master that??
rabbit
