I have built a controller on my ipad. i have everything mapped but i am having issue finding some of the command lines. here is what i need command lines for:
loop, time line mode, bpm,
bounce, back, forward,
pause, random, bpm tap
resync,4,2,1,1/2 beat, cue 1-3,
trigger 1-3
i am looking for layer command lines not clip command lines. the only ones i have found are clip commands.
although i know this a LOT to ask, i do not want someone to do all the work for me. i just would like to know where to find these commands. i want to know so that if someone asks me i can tell them.
thanx
The Digital Gigalow
OSC Command Lines...Where do i find these
TheDigitalGigalow
Re: OSC Command Lines...Where do i find these
in 3.2.0 you can set resolume to midi mapping mode, clicking any controllable object gives you its OSC command as text in the bottom left corner of the interface.
but basically the layer controls are the same as the clips but on a layer1/video/ path
