New Bug
cat_
Post by cat_ »
Got a bit of a problem here, got a gig on saturday, dont suppose you'll fix it if you've got a new version on the way!
I as I've mentioned before run at full pal, although I've got this problem even if I lower my res.
Resolume works fine for a while (2 layers a couple of FX) but starts to slow down then often the output stops or else goes blank completely. The interface still works, shows the playhead moving as normal but no output. This is with the latest nvidia drivers (mx440) xp sp1a (also without sp1, I upgraded hoping it would fix it.) I'll post again if I find out more or a workaround! More for your information really
whith what codec are your video files compressed?
cat_
Post by cat_ »
PICvideo Mjpeg, I've recently upgraded from win2k to xp, 2k worked fine! I've just tried rolling back the drivers and using 320x240, Im using quite a few freeframe+ plugins, ie brighten and saturation mainly (that was my fix for sluggish triggering/fx/mixing) so it could be them, Resolume locks up when I try and quit after this problem also!
I'll try a few more things then its back to 2K! (I'd occasionally get this with 2K with long sets, but this is after a couple of minutes!)
Any suggestions would be greatly appreciated!
Cheers guys!
Cat
cat_
Post by cat_ »
No its not the freeframe, happens without any fx!
