hey
right now i am trying to work on something using a jpeg i created from a pdf in photoshop. the image itself is fairly high res but when i open it in resolume the image looks, messed up. i wouldn't say pixelated but the lines aren't straight. there's like a break every couple pixels in the line so it's like staccato or something.
the output i recorded looks the same way. i am experimenting right now with lower quality jpeg settings but they won't open at all once saved for some reason.
any help would be appreciated. thanks.
best photoshop setting for resolume 2.1
Re: best photoshop setting for resolume 2.1
Create your JPEG file at the resolution that you'll be playing it back in. When a high res image gets scaled down to for instance 320x240, straight diagonal lines will appear pixelated because of the loss of resolution. In general, fine line work is very hard to display at low resolutions.
