Hi people
I am new to avenue as well as sending Midi Signals!
Here goes:
I would like to use 1 computer to play traktor pro and send a signal to another computer with Avenue.
I think that I will need to set the midi send on traktor to on and link the two computers up with a network cable?
then I can change the settings on the Avenue machine to recieve the midi signal from the traktor computer?
Is this correct so far?
Any help would be great
dave
beginer needs help
Re: beginer needs help
im pretty sertain that traktor only sends midi clock. ( it just makes sure things run at the same tempo ) other than that you wont be able to control anything in avenue from traktor.
sorry, i think that is what I ment. Ideally Resolume would be able to show visuals at the same time as the musics beat. eg a Pulse?
Hey Dave
Have you checked our walkthrough for syncing up Live and Avenue? It's pretty much the same worlkflow for Traktor http://www.resolume.com/avenue/manual/tutorial_live.php
