hi
am a beginner for resolume avenue 3.1.....when am doing projection with resolume avenue 3.1 the performance of the software becomes very slow while adding the file in layer so am not able to understand where is problem well my laptop has
AMD Turion 64x2 mobile
technology tl-58
1.90ghz, 2.43 gb ram
NVIDIA geForce 7150m/nForce 630m
Please suggest me what shall i do......
Thanks......
is my laptop right for resolume 3.1
Re: is my laptop right for resolume 3.1
I'm sorry to say, but it looks like your laptop has a graphics card which uses shared memory, so it's not really good for use with Avenue
is there any solution for it or i have to buy a new laptop for me......if yes wht would you suggest......
regards......
regards......
unfortunately, a new laptop with a better graphics card is the only option
Can u Please suggest me a gud laptop for me that will be great helpfull for me.......
depends on how much money you wanna spend???
but the math is easy : u need at least Intel Pentium Dual Core processor 2,5 GHz , 4 GB RAM, 7200 rpm SATA II HDD, and of course a graphic card with external memory .. and eSata or Express card port for fast external hard drive connection......
