hi
is there some way of having dxv-mov files showing thumbnails in windows 7 (x86)?
also is there a reason why dxv does not appear as a quicktime codec option in avs video converter\tools?
thanks
DXV on explorer
Re: DXV on explorer
Hmmm. Those two could well be related. Could you try doing a separate install of the DXV codec?
Re: DXV on explorer
if you mean in a different system... well... in my x64 its the same... nothing
if you mean instaling the codec only after resolume... same thing... nothing appears aswell
if you mean some other thing like installing it in a diferent directory, then, where?
Re: DXV on explorer
I meant the second one, but thanks for trying all of them!
Are you using Quicktime or QT Alternative?
Re: DXV on explorer
Is the DXV codec installed in the correct directory? It should be in C:\Program Files\QuickTime\QTSystem\DXVWindows.qtx
Re: DXV on explorer
yes no problem there... normal instalation, no weird workarounds and stuff like that
Re: DXV on explorer
meh. codec correctly installed and it doesn't show up. that's windows for ya, i guess
we've had some other issues with win7 and dxv. i'll add this to the list. does it show up in other apps?
Re: DXV on explorer
it does at least in both c4d and after effects... and the thumbnails appear fine on both resolume and AE
but it shows up on the mac version of avs video tools? that's strange...
hope that you can fix this though, because im looking at a lot of content in mkv that i would hate to recode through avi, just to later recode them from source...
Re: DXV on explorer
i've sent a message to the avs tools ppl here's the link with their response
http://support.avs4you.com/QuickRedirec ... 96a64852f2
i hope they implement it soon
