column names desapearing
werlin
Post by werlin »
what it says... sometimes on open other times on click
but only the ones which have clips in them
Re: column names desapearing
Ghost column names eh? Strange indeed. Could we have a screenshot?
werlin
Post by werlin »
it starts like this when i open resolume, and as i click on the columns they disappear
and they stay that way even if i switch decks
not a big thing but might make a diference for some, just thought you should know
werlin
Post by werlin »
while we're at it just one thing that i discovered yesterday...
clips wont start in bpm mode, if audio controls are disabled in view menu :| (i have to change to timeline, then play, then change to bpm while playing)
im only vj... dont need the audio controls all spread through the layout, just need for clips to work in bpm
I'll make a ticket for the disappearing column name, could you send us your log file so we have your system specs (via the send feedback option in the preferences)?
I can't reproduce the clips not starting in BPM sync mode. Does this happen to all of your clips or only to specific ones?
werlin
Post by werlin »
i've sent the log file, although im seeing a couple of things that are being read wrong by resolume...
1- i would die 1st before ever instaling WVista :mrgreen:
2- the processor speed is wrong, its actually 2,33ghz
3- there's 3gb ram not 2gb
on the second matter: all clips... and it seems that showing audio controls no longer works as an workaround option... but it worked yesterday somehow :|
