pixels in space
Tschoepler
pixels in space
Post by Tschoepler »
hey,
the pixels in space effect doesn't get copied when ctrl-dragging a clip which I applied the effect to. Can you reproduce this? I got particles > pixels in space > blur applied in that order from top to bottom. the other two do get copied.
edit: ok_mmhh. for some strange reason it is working again. I had to restart several times and I killed one clip that had an IR-Cosmis-Effect applied. maybe that did the trick. now everything is working fine again.
