Post
by fruitygreen »
Got 2 of them.
I use it with my 8 core xeon , win7 pro64bit, with Resolume.
Use to mix 2 other laptops to it. Via HDMI's. Non-HDCP
Warning will not work with Integrated intel graphic chipsets with HDCP.
Workaround is through a vga with scaler to 1080 or 720 HD.
A defined HD resolution only works.
I will upgrade to another board with 6x PCI-E x16 and USB 3.0 ports, so I can add more HD sources to it.(laptop, hd cams,etc)
There is a little latency but o well it works great.
