I have a big problem with resolume, it's using up all my cpu power, even when there are no movies imported or being played. My specs are : Windows XP on pentium 4 (labtop) 2,6 GHZ with 512 ram and an ati radeon mobility 9000, 64mb.
It also opens up 2 instances of resolume whenever I start the program. thanks for your answers!
resolume 1.5 uses 100% cpu power
this is all completely normal...
if you do a little research you'll find that Resolume is (like most games) designed to reserve 100% cpu power...
I think the program doesn't launch twice the same instances... But two different modules (one for calcualting/mixing, one for displaying (second monitor))
there is no big problem...
