I am finding that batching clips to Quicktime DXV's in Compressor results in a non-descript failure. Using the regular 'Batch Export' feature in Final Cut Pro causes FCP to crash (poof) when exporting to DXV. I am using FCP 6.0.6.
If I manually export single files in Quicktime Pro itself, it works fine. But batching would make life a lot more convenient for sure.
Using a 1st-gen MacBook Pro with 10.5.8.
Any ideas?
-FONG
DXV batch failures
Re: DXV batch failures
Hey Fongaboo
We haven't tested extensively with Compressor, but a quick test batch encoding a couple of Photo-JPEG clips worked fine for us. Are you running any codec packs, or other things which may interfere with the encoding process?
