Does anybody actually use the Random Direction button for playing clips?
It goes to a random frame every frame, which seems like a weird thing to have as a basic function of Resolume; it'd be fine as a plugin, but isn't useful enough to go next to the play and pause buttons.
I think that button ought to act like the Random setting in Resolume 2 did: when a clip is triggered, it starts from a random point and then plays normally from there.
That button would then belong with the play-modes (next to the rewind-on-start and continue buttons)
I can nearly replicate this action by quickly hitting the randomise and play buttons in turn, but this looks messy.
Random clip-start point, like in Resolume 2?
Re: Random clip-start point, like in Resolume 2?
yes. its great for glitchy less repetitive visuals. i use it like that a lot with techno, dnb & glitch, usualy with graphic / mo graph elements.guplik wrote:Does anybody actually use the Random Direction button for playing clips?
Just so you know, some additional 'Jump to a random point and play' features are in the works.
Excellent, thank you!goto10 wrote:Just so you know, some additional 'Jump to a random point and play' features are in the works.
I don't suppose that'll appear before next Friday, will it?
- rxfromparis
+1 for Jump to a random point and play
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000
and please .... random for the FFT also ... PLEAASE =)
Can you elaborate a bit on that?and please .... random for the FFT also ... PLEAASE =)
Well as stated already in my other post - possibility to have all the options you have on the normal timeline - Random, Forward- Backwardbouncing ... veeeeeeery important.
- Tschoepler
+1 for random and !play! not just still frames
- Tschoepler
Hey Tschoepler! I have a MAX patch for you (and everyone else of courseTschoepler wrote:+1 for random and !play! not just still frames
Get it here: RrrandomPlay 0.1
