Using Fraps to record
rxfromparis
Post by rxfromparis »
Has anyone managed to use Fraps to record anything other than the output monitor in the program window??? :roll:
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000 :))
Basic
Re: Using Fraps to record
Post by Basic »
there is a tiny bit in here which says fraps can be a little shaky when it comes to getting the fps correct.
http://www.resolume.com/forum/viewtopic.php?f=13&t=7120
by the look of your rig im surprised you'd have any problems.
also have you considered an external recording device? :)
rxfromparis
its not the fps, thats great, getting a stable 30fps, it's just the focus of the Fraps recording window thats a problem. :(
Basic
Post by Basic »
ah I see my apologies. hmmmm let me think :)
