CompEditor 0.1 beta
Tschoepler
CompEditor 0.1 beta
Post by Tschoepler »
Hey fellas,
I finally finished the beta of my comp editor.
Usage:
1. Click "read" to feed MAX with an avc–file.
2. Specify deck#, layer# and track# of the track you want to move to a different deck.
3. Specify newDeck#, newLayer# and newTrack# where you want the clip to be moved to.
Make sure the track–slot is empty and the layer# doesn't exceed the comp's layer–count.
4. Activate "start edit" and wait for the process to finish (yellow cross disappears).
5. Repeat Step 1 through 4 if necessary.
6. Click "write" and enter the name of the new comp plus the suffix (e.g. demo.avc). Otherwise you will get a txt file.
!!!Attention!!!
This app is in beta stadium. So please don't overwrite any existing comps. Always save to a new file and test it inside Avenue before eventually deleting the original avc.
!!!Attention!!!
Known Bugs:
- The app malfunctions if you have both sides set to the same values.
- Feel free to report any bugs in this thread.
In Work:
- Warn you if clip–slot is already in use by another clip.
- Add layers to comp if necessary.
CompEditor 0.1 beta.zip
(158.29 KiB) Downloaded 964 times
Re: CompEditor 0.1 beta
Handy!
Tschoepler
thx
jim
Post by jim »
you need to implement a like button on the forum for things like this :)
Tschoepler
+1 :lol:
