Playing more then one clip
This is proberly so dumb, but i just cant figure out how to set resolume to play a series of clips..
Re: Playing more then one clip
put clips into separate layers and then trigger the whole column and that will work... you need more thank 1 clips for it to work though
- Tschoepler
And don't forget to check weather you have them set to play only on "A" or "B" (see "fading" in the manual).
