Video Capture Card! Urgent
Pedro Lopes_
Post by Pedro Lopes_ »
I'm thinking of buying Miro Dazzle DVC-80 USB video capture card. My question it's that if i ad an input to the card for example a camera, does Resolume captures what i'm filming? By the way, does Resolume capture with any video capture card with any input source?. Please help me, it's urgent. Best regards for all of you.
we do not have this card not have we ever tested it so i hope someone else has some experience with it ...
Pedro Lopes_
But does work with other card? I mean with other that you ever tried, it's possible to interact with resolume?
Pedro Lopes_
Thnks anyway, i bought a Miro VOX MS8609 Video Card, it was a great deal for a 89€ external card, and it's fully functional with Resolume. Another gadget to had to your list :-)
focus_
Post by focus_ »
I Am using the pinacle video input card.
simple and cheap. esey to use
videoteque_
Post by videoteque_ »
Hi Pedro,
Which resolution do you use???
Digicat_
Post by Digicat_ »
Check this out. At my club I installed a firewire card. I use a panasonic DV Cam (large format tapes). The other night I was recording fotage into Premiere Pro and as a test I loaded the un-cinepaked footage into resolume and it worked immediatly without having to be transcoded to cinepak.
very nice, just firewire and premiere pro...
Digicat_
Post by Digicat_ »
vj_fusion_
Post by vj_fusion_ »
Pedro
I've had success using cheap webcam's thro' the USB port's then capturing into Resolume 1.5, set them up round your gig venue, then switch them in Resolume as required.
Check out the results at http://www.hollowsphere.org/burst%20couch%2011.htm
