hey my avenue used to work perfectly whit an older version but now i upgraded to 3.2 and it says that my video card isent good enough
That cant be right can it ?
Im using a
Club 3D GeForce PCI-E GTX260 Core216
on a desktop whit 8 gb ram, fast harddisk and quard core.
Your video card has insuficent specks
Re: Your video card has insuficent specks
I had a similar issue and all i done was update the drivers. i thought it was already updated but got the newest one and worked fine.
also are you mac or pc?
if your pc try and use this...
http://www.devicedoctor.com/
it lets you know exactly what needs updated and will link you to it!!!
hope you get it sorted!
