some days i ago i started converting my "old" videocontent to the DXV-format.
I used my workstation @ home, downloaded the newest codec, newest flash aso, for converting i used moavi.
every video i converted this way are crap, if i put them into resolume i dont see a thumbnail/preview pic but the video is fully loaded. I can see the preview of the video but i can´t start it on fullscreen.
I tried a converting on my VJ-workstation and everything is fine, normal preview pic, normal playing of the video. Any ideas whats wrong???
greets
Problems with DXV
Problems with DXV
| EVGA SR-2 | 2 x Intel Core i7 X5650 | 48 GB Corsiar DDR3 PC12800 | 2 x HD5870 Eyefinity 6 | 1 x GTX580 | 256GB Samsung 840 PRO | 160GB Intel Postville | Win 7 X64 | Resolume Arena 4 |
Re: Problems with DXV
Hey Vertex
Is there any difference between the two systems that you can think of (other installed codecs, operating system, installed quicktime version etc)?
i have to check the quicktime version, but on my home workstation i made the whole AE CS5 and Cinema 4D content and render it with the codec and it works.
the maschines are a bit different, home is a Intel Core i7 980X with 12 GB DDR3 and Intel Chipset, the VJ-machine is a AMD 1055T with 8GB DD3 and AMD Chipset.
