I have strange problem. I have made composition in QC in which many elements are activated by midi keyboard (or MaxMSP. It works like a dream in Quartz Composer. When I try to do the same after importing that composition into resolume it does not react to ranges of midi notes: 32-63 and 96-107. What is going on?
I have switched off all MIDI mapping during the tests with QC composition.
Also I have checked MIDI mapping in resolume and everything is OK.
RobR
Resolume+QTZ MIDI Problem
Re: Resolume+QTZ MIDI Problem
Can you send the .qtz file to support[at]resolume[dot]com? Then we can take a look and see if we can figure out what's going wrong.
