after finding my key (doh!!!) spending two days trying to configer "ultramon"(twin monitor management) and haveing the weridest things hapen to my comp finely, yes i know i biged it up but dont use it with resolume theres some kind of clash between the two progs and non of them work, i finely decided to ditch it and try again
well what do you know it works a bloody treat i can tell you
i've not had any problems with it since,
though my merchine is no slug on valium
1.4 atherlon, 512 ddr, gf3 with tv out, matrox 4mb pci graphics card.
i run the out put through tv out and the interface with the pci card, chears for the advice around the dual monitor set up helped a lot.
so all in all a top little numberif you got the comp to go with
though i'd like to see some add ons, text genorator would be good, plug in efects, the ability to hook up to outher progs but hay we wait and see.
the big test will be the gig on saterday i'll let you know how it goes
