Is there a way to set the layer-focus to the layer of the clip which is currently in preview/composition when triggered?
Background:
I've MIDI mapped (at layer level) speed, scale, position, in, and out. When I trigger a clip (by mouse or MIDI) I'd like Resolume to focus to the current layer of the clip just triggered (either to preview or composition), so I can use my knobs to adjust speed, scale, etc. before I trigger the clip to composition.
Can't believe that it's not possible
Edit:
Found a workaround: I remapped position, and scale from active layer to clip properties (in Application MIDI Map / Layer) and now changes are applied to clips in the preview, independent of the layer focus. - One thing, the clear layer button does not work (of course) as the focus is on a different layer
