Im looking for a converter tool, batch converting that is.
I should convert from any given format to DXV and it should run on OSX 10.6
Any good tips here??
// Bjørn
[Q] Good program to convert files to DXV
Best regards
Biorn Christiansen
ChrisB
Biorn Christiansen
ChrisB
Re: [Q] Good program to convert files to DXV
do you use programs like After effects?
im not too sure of one on mac but you can batch convert stuff in AE.
Hope this helps...
in fact i have just found this...
http://homepage.mac.com/major4/
Ive used this on pc and it works a treat. also make sure you have the dxv codec installed
Hope this helps...
Just use the adobe media encoder
or
Lived Instruments, Batch Export Utility
http://www.lividinstruments.com/support_downloads.php
or
The Adobe Media Encoder is really the best encoder you can find. But you have to buy adobe after effects (and it's expensive).
yeah mpegstreamclip and also adobe media encoder. I have just recently been using adobe media encoder and its very good!!! works nicely with the rest of the adobe suite!
- Tschoepler
look here for some more info viewtopic.php?f=13&t=7026&hilit=batch
Im media streamclip (squared5.com), the option to convert to .mov is possible through list--> batch, but so far I found no option to select the dvx option within the .mov batch conversion process. The .mov conversion yields extreme square pixels results, very bad quality. Anyone has some tips on this?
r
r
MPEG Streamclip
in your batch export settings choose the DXV3 option in the codec drop down. Set quality to 100, leave scaling alone and disable audio if you don't use it
