Its kind of weird because its only the files i have downloaded ex. that does this
http://www.vjvault.com/view_video.php?v ... ategory=mr
i converted all my files using mpeg steamclip, and choose ignore alfa channel.(doent work either way)
The masks works perfectly with my other clips ?
Ohh and all my clips are dv PAl mov with the dwv compressor and im on a pc
thx
**edit** Now i tried to convert it to SWF files and its stil the same
