BMP counter/ beat sync not working
editdyl
Post by editdyl »
I'm having a problem where my beat sync isn't working. The little box with the rotating yellow quadrant isn't moving, and my video clips don't seem to be syncing to the master clock? Any help?
Re: BMP counter/ beat sync not working
Do you have midi clock enabled for any external midi devices?
HerrNieDa
Post by HerrNieDa »
i had problems with my built in soundcard...
it stopped working when switching input or something in resolume
resolume needs a soundcard selected to run the bpm counter!
i solved my problem by deleting the preferences.xml in the resolume folder in your "document" folder!
tius
Post by tius »
this is grate, I just have the same problem 5 min before my gig this bmp counter stops , I thought I will kill myself.Its good you are here to help guys:)!!!!
