Problem with IRkeystone3
Straight-Disorder
Post by Straight-Disorder »
I have a little trouble with the plug IRkeystone 2 or 3.
so ... as soon as I apply IRkeystone to a composition, it creates a geometric pattern (fine ... but visible) on the video output. I used it for installation (http://www.straight-disorder.net/ >> ]Panoramix [# 6) with 3 screens / 3 VP + 1 MatroxtripleHead and this plug is almost indispensable ..:)
Would there be a particular setting of the video card that could solve this problem? or other solution ..?
thank you in advance for the help ;)
Pascal aka V.JaX
Win7 64bits // Video card nvidia GTX470 (1280Mo) // QuadCore processor // 4GB of RAM // Resolume 3.3.1 + DXV 2.1.1
Last edited by Straight-Disorder on Sat Nov 06, 2010 22:06, edited 1 time in total.
STRAIGHT DISORDER
[Audio-]Visual [Live] Works
contact@straight-disorder.net
Tschoepler
Re: Problem with IRkeystone3
Post by Tschoepler »
There is checkbox "show grid" on the very bottom of this plugin. uncheck this.
Straight-Disorder
no it is not due to the adjustment frame of the "show grid" checkbox ;)
the frame is much smaller has nothing to do with these help lines, it's more a display issue and rendering the distorted picture, that's why I thought of a particular setting of video card settings ...
STRAIGHT DISORDER
Tschoepler
mind uploading a magic screenshot? that usually helps ;)
Straight-Disorder
clearly..;)
here...
you can see it on the white areas...
thanks..;)
STRAIGHT DISORDER
Tschoepler
OK, now I understand. But I can't recreate the error.
Maybe you should contact Ivan (http://www.irworkshop.com).
