Since it is not always an option to use the triplehead for three screen projections, it may be wise to only use two screens
Because all my content is 1920x480, my answer is to only send video to two projectors while still using the triplehead.
My question is:
Is it possible to horizontally move resolume's output feed?
Think of it like a vertical fold on old televisions.
Except it would be horizontal so I can adjust my output to be centered on two screens instead of three.
Thanks you!
can resolume adjust output feed horizontally?
Re: can resolume adjust output feed horizontally?
You can use the layer position to position your content.
What also would be a good workaround is to attach a monitor to the 3rd output if there is no projector.
