I am playing 6 layers of video at 1024 x 768, and it seems my graphic card can handle this beautifully: its running at around 70 Fps. The problem is when I try to record my sets, even with a second display output disabled, it falls to 17 Fps, and the output stutters quite a bit. Any solutions? I'd like to record my work...
specs:
Intel quad core i7 at 160 Ghz
8 Gb ram
Nvidia Geforce GT 460M
HDs are 7200 RPM internal
trouble recording video
- rxfromparis
Re: trouble recording video
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000
Thanks for pointing me to that thread. The Fraps option looks really interesting! I will try it out and report back my findings.
- rxfromparis
there is a 3.2.4 version that will out soon : you can record fullscreen screen 2 with no problem
i have been waiting for them to update to post a complet trial, but i was able to record a stable 25 fps in Hd with Avenue running 4 layers of hd with the 3.2.4 beta of Fraps.
cheers
cheers
