Set default parameter values for source plugin
marcusren
Post by marcusren »
I'm trying create a set of FreeFrame source plugins using OpenFrameworks and ofxFFGL and I've been trying to figure out if it is possible to set default values for parameters shared between the host and the plugin. At the moment, it looks like Resolume automatically chooses default values for my plugin parameters when the plugin is first loaded. However, these values do not represent what I want users to first see. For example, in the constructor of one of my plugins I have the following:
Code: Select all
_branchSpeed = 15.0;
addFloatParameter( "Speed", &_branchSpeed, 1.0f, 50.0f );
Even though I have initialized the parameter's value to 15, Resolume re-sets it to either the min or max parameter value. Is there anything I can do about this?
Thanks in advance for your help,
marc
HerrNieDa
Re: Set default parameter values for source plugin
Post by HerrNieDa »
you can use presets in the effects of avenue... here the parameters are saved... but not updated if you want that, but maybe you can communicate with this :?:
drand48
Post by drand48 »
Hi, have you tried downloading the latest version of ofxFFGLPlugin ?
It seems like a bug from the first version of the addon.
You can download a zip here:
http://code.google.com/p/ofxffglplugin/downloads/list
or check out the code with svn:
svn checkout http://ofxffglplugin.googlecode.com/svn/trunk/
Daniel
marcusren
Post by marcusren »
Thanks Daniel, I'll give that a try :)
